camber issues
Old Oct 16, 2011 | 11:43 AM
redmufn's Avatar
Arrow camber issues
so i recently put BJ spacers on my '93 pickup and now my camber is all messed up.... wondering if it would be fixed by an alignment ?
i have been waiting to get the front two tires because i dont want them to get chewd away...
its kinda hard to tell but here are some pics..
you can see the wear on the inside
still hard to tell...
got the km2s in the rear tho, now shes waitin for the front.
Old Oct 16, 2011 | 11:48 AM
4Crawler's Avatar
An alignment is recommended after installing spacers or even adjusting the ride height with the torsion bars:
- http://www.4crawler.com/4x4/ForSale/...GetAnAlignment
Old Oct 16, 2011 | 11:57 AM
redmufn's Avatar
yeah i read that on your website. oh BTW thanks for the spacers!! easy to do and just what i wanted. but yeah i wasnt sure if an alignment would fix the camber?
Old Oct 16, 2011 | 12:06 PM
4Crawler's Avatar
It generally will, but if your front end was right on the edge of being able to be aligned before the lift, then the spacers might push you past that point. But in that case, you might just need to try another alignment shop, as they are not all created equal.
Old Oct 16, 2011 | 12:09 PM
redmufn's Avatar
the alignment was spot on before, i still drives stright if i let go, its just the camber. the camber also makes it drive funky so it needs to be done, thnks for the help!
Old Oct 16, 2011 | 12:29 PM
Oh6War's Avatar
Question. you guy know if the specs on the alignment machine will be incorrect if I go from a 245/75R16 to a 265/75R16?
Thanx
Old Oct 16, 2011 | 12:38 PM
redmufn's Avatar
wouldnt the settings be adjusted? idk im not familiar with alignment.
bigjstang
Jun 2, 2025 03:56 PM
nvdesertrunner
May 11, 2020 08:18 PM
crammit442
7
Nov 29, 2017 12:30 PM
justdifferentials
Just Differentials
Sep 17, 2015 06:14 PM
rjtrials
Aug 6, 2015 07:25 PM
