90 Extra Cab rear driveshaft...im stumped on what to do
Ive got a 90 extracab that I bought without a rear driveshaft. The previous owner torched off the bracket that holds the mid bearing claiming that he was running a one peice driveshaft. From flange to flange it measures out to 64 inches, Is there any drive shafts out there that would fit this or will I need to have one custom made. Any help would be greatly appreciated.
thanks,
cam
thanks,
cam
you will find a one piece toyota drive shaft that will fit from a longbed toyota. Good luck finding one as well. I would recommend fixing the cross member and just getting a two piece.
If I were you'd I'd just get a custom one piece shaft with a double cardigan joint on the t-case side and you'll be good to go. I know some places can make them from scratch for you however it will be much cheaper if you bring them a donor to work with.
