Just bought a 91 p/u and have a power steering question
I was wondering if I could buy a smaller belt and do away with the ps or is that not possible?? I've never changed a ps pump, just need a quick fix for now...
I believe that the P/S pump is also the belt tension adjustment. If thats the case you cant do away with it, otherwise you would have to "roll" a smaller belt onto the crank and w/p pulleys, with no way to ever adjust the tension...
If the P/S pump is permanently affixed and not used as a tensioner for that belt, then you could prob get away with a smaller belt and eliminating the pump on that belt. But if its a moveable, tensioner unit pump, then yeah, I would suggest changing it... Some pics would tell me better. Since this is the '84-'85 section, you may wanna check in the '91 section. Be sure to list your engine size...
Dah...if you remove the belt, nothing else happens, you just lose your power steering(pump's no longer being driven). Unless that same belt is driving something else, like say an A/C compressor. In which case, bye-bye A/C too. As long as you have an alternator belt you're good to go(since that one drives the cooling fan too, and the water pump if 22R-E).
Jun 1, 2021 01:51 PM
MMA_Alex
25
Apr 18, 2017 05:07 AM
