stuck in 4wd after diff and tranny swap
i have had a lots of problems after i swapped trannys. i went from just having no reverse to have a tranny that works in all gears just makes a whinning noise in everyone expect for 4th. then i blew my rear diff and thought i had a welded 410 spare diff but its not. i put that in not checking and the front wheels skid on pavement in 4wd. i also could not get out of 4wd. for the longest time, this happened once with my old trans and tcase. what could cause this
Ive had trouble shifting out of 4wd before and shifting into reverse and backing a little usually lets me shift out of it. Are you sure the shifter is installed correctly? Tcases that sit for a long time become hard to shift. I know, I just installed one! I put a gob of grease on the TF shifter and worked it through all shifts a few times and it is much better now.
ill be posting pics of my last diff that went bad, soon. as for being stuck, it just kinda fixed its self, i believe since the tcase was sitting for awhile, it just kinda binded everything up but its up and going now
jerusry
Oct 19, 2015 05:28 PM
Iceman4193
Jul 15, 2015 04:48 PM
TokyoD23
Jul 12, 2015 06:01 AM
madxman21
Jul 9, 2015 10:26 AM
