Idea: 1980's Toyota 1 ton dually ... SAS conversion??
Old Sep 17, 2011 | 03:33 PM
ct_tuckrunner's Avatar
After 5 years of driving a Toyota (first a '94 4runner, now an '87 xcab) I suddenly find myself in need of a bigger truck for work. I got to thinking: Has anyone ever SASed a 1 ton Toyota pickup, which as far as I understand only came 2wd? It seems to me to be the best of all worlds: 1 ton carriage, long bed capacity, Toyota reliability, diesel... and 4 wheel drive with a solid axle in the front.
The issues above and beyond a typical SAS conversion would seem only to be:
Swapping the transmission/transfer case
Custom driveshaft(s)?
Lifting the rear to be level with the front
I am open to comments and ideas, thanks!
Old Sep 17, 2011 | 04:56 PM
Mr_Random's Avatar
Saw something like it in Northern AZ... looked like a smaller camper conversion, but diesel, dually, and 4wd. As far as I remember, dually trucks had a different lug pattern from normal, so that may also be a small obstacle for the front axle.
I think the diesels of the time share the bellhousing pattern of the 22r, and if you are seriously considering doing the work of swapping to 4wd, it may be beneficial to add a crawl box to the mix. Would be kinda like the older full-size diesels with their two speed rear ends, plus you are already gonna have to redo driveshafts.
Old Sep 18, 2011 | 09:54 AM
twistedyota's Avatar
sounds sweet, u should go for it.
Old Oct 12, 2011 | 10:04 AM
99 sas runner's Avatar
I've always wanted to do that!
Old Oct 12, 2011 | 10:23 AM
CitrusTheDragon's Avatar
sounds awesome I have kinda wanted to build something like that for a while now.... if you do it make sure to take pictures....
Old Oct 16, 2011 | 05:58 PM
thrice's Avatar
This sounds awesome! I agree you should go for it!
crashburnoveride
Aug 28, 2015 09:20 PM
msane99
Jul 11, 2015 08:08 PM
skoti89
Jul 6, 2015 07:45 PM
karbin
Jul 5, 2015 11:37 PM
