Help removing lens from Gauge cluster..Tips on recalibration !
I have a 1988 Toy PU that I need to recalibrate a gauge cluster from a V-6 to a 4 cylinder. Is there a good easy way to remove the clear lens without damaging it. Any other tips to make the swap easier is appreciated.
Thanks,
22R88
Thanks,
22R88
the lens is just held in with "tabs" (press fit) .. its always best to disconnect everything so you can pull the whole "cluster" unit out .. then just a flat/spade screw driver to "pop" the tabs out .. and your good to go
https://www.yotatech.com/forums/f116...w-pics-179106/
Read this thread to do your recalibration...Good Luck....Have fun!!!!
Esibnitsud
Jul 30, 2015 08:19 PM
Poncho0206
Jul 10, 2015 06:21 PM
