Coil Pack Issue
Coil Pack Issue
Need some advice in regards to my coil packs.
The idiot, check engine, light came on, I had the computer scanned and found that Cylinders 1 & 4 where miss firing.
Got a used coil pack, off a 2003 tercel and have same issue.
Please know, I'm not mechanically illiterate, just not up to speed on this "No timing or distributor" system.
Although I am working on it.
Question #1: Are the 1-4 & 2-3 packs interchangeable?
Question #2: If packs are interchangeable, and problem persists, where do they get their signal from? IE, speed sensor, timing sensor, what have you.
And yes, plugs and wires already changed. Just thought I would ad that for clarity.
Thank You in advance.
2) from the Engine Control Module, via the igniter. Look at the second page in the link.
http://www.ncttora.com/fsm/1996/SIL/...mci/013sis.pdf
Thank you for the responses. The truck is a four cylinder, so just two coil packs. Did install other pack, pulled #1 wire off @ the coil pack, the miss fire is coming from the pack. So now I need to find where the pack gets its signal from.
Because the problem is to the pack. If you were following, this is the third pack installed.
Problem still persists. The odds of three packs with same problem are slim.
Thanks for the input though.
If you moved the pack and the misfire followed it then that means the pack is the problem and not the wiring since you are using different wiring when you move the pack. Thats the whole point of moving the pack, to test the wiring.
the1998sr5
15
Jul 14, 2020 08:35 PM
