What oil pan to use on my 3.4
I have been searching for an answer on this and it seams a lot of people have used the ORS conversion kit or a t100 oil pan. I am doing a 3.4 swap into my 89 2wd pick up. My truck had a 22re in it, I was able to pick up a 3.0 oil pan and i was wondering if this is correct for my application. if so are these the correct PN for the dip stick, dip stick guide, and union Dipstick - Toyota 15301-62060
Dipstick Guide - Toyota 11452-62060
Union - Toyota 90405-10033 (some members here listed 0405-10033
Here are a few pics of what i got going on
will be running a supercharger and a SDS system
A 2WD truck requires the use of a 3.0L 2WD truck pan. Its a "middle sump" application.
Part number is 12101-65021
If you use the 2wd 4Runner pan, it won't work. 2WD and 4WD 4Runners use the exact same oil pan.
A 2WD T100 pan is a rear sump pan, which will hit your cross member. You only use the T100 2WD oil pan if you have a straight axle in the front.
Sep 4, 2015 09:27 AM
