What oil pan to use on my 3.4
Old Jul 6, 2011 | 06:14 AM
jayglamis's Avatar
I have been searching for an answer on this and it seams a lot of people have used the ORS conversion kit or a t100 oil pan. I am doing a 3.4 swap into my 89 2wd pick up. My truck had a 22re in it, I was able to pick up a 3.0 oil pan and i was wondering if this is correct for my application. if so are these the correct PN for the dip stick, dip stick guide, and union Dipstick - Toyota 15301-62060
Dipstick Guide - Toyota 11452-62060
Union - Toyota 90405-10033 (some members here listed 0405-10033
Here are a few pics of what i got going on
will be running a supercharger and a SDS system
Old Jul 7, 2011 | 08:54 PM
RobD's Avatar
You use the 3.0 oil pan, but you'll also need to use the pickup from the 3.0 as well. The oil pan is sealed with FIPG material. I used Permatex with mine.
Old Jul 7, 2011 | 09:34 PM
DeathCougar's Avatar
A 2WD truck requires the use of a 3.0L 2WD truck pan. Its a "middle sump" application.
Part number is 12101-65021
If you use the 2wd 4Runner pan, it won't work. 2WD and 4WD 4Runners use the exact same oil pan.
A 2WD T100 pan is a rear sump pan, which will hit your cross member. You only use the T100 2WD oil pan if you have a straight axle in the front.
Old Jul 11, 2011 | 05:52 AM
jayglamis's Avatar
ok i have a 2wd 4 runner pan that is no good i need to find a 2wd pick up oil pan and pick up then, and i would run the the dip stick parts from the pick up as well correct
Old Jul 11, 2011 | 08:40 AM
Correct, you need a 2WD Truck pan, and dipstick parts.
A 2WD 4Runner pan is the exact same as a 4WD 4Runner oil pan.
Old Jul 11, 2011 | 10:17 AM
jayglamis's Avatar
^^^^ thanks a lot for this info and the pn of the pan. would u happen to know what size tap i needed to plug the stock dipstick hole?
Old Jul 11, 2011 | 10:45 AM
That I do not know. The information should be on Offroad Solutions website
Sep 4, 2015 09:27 AM
93toyoguy
Aug 2, 2015 07:41 PM
thefishguy77
Jul 30, 2015 10:59 AM
irritech
Jul 27, 2015 05:15 PM
toofly1999
Jul 25, 2015 07:09 PM
