Recommend a shop in/near Las Vegas to rebuild my 5VZ-FE
Like the title says..
Anyone know of a trustworthy shop, or an OCD meticulous mechanic with spare time, that could rebuild my 5VZ-FE out of my 99 4x4 4Runner?
She runs fine.. Great actually. Just feels a little tired as the years have gone by. I'm about to throw on a lift, bumpers, 33" tires, and some other crap... And I don't wanna be going any slower. I'm also planning on supercharging her, so I figured I'd get a new engine.
Also, I'd happily travel to Utah, California, or Arizona for the right Shop.
I know of NVT Engines here in Vegas, and LC engineering in Lake Havasu.... But I've heard horror stories about them both.
How many miles on your rig? Your motor shoud go well over 300K without any major issues. Have you done a compression test? That would help tell what you have. If you end up doing a rebuild, make sure the shop installs good quality parts as Toyota used when they built your engine. Good luck.
If the compression test comes back low, I would have your valve lash checked before taking the motor apart.
Some things that can cause loss of power are, dirty air filter, plugged cat. converter, faulty engine control component............... Check it out first, you very likely have some minor issue causing your loss of power.
nframe
3.4 Swaps
Aug 16, 2015 09:03 AM
5vzfe, 89147, engine, kit, las, nv, nvt, rebuild, rebuilders, rebuilding, service, shop, supercharger, toyota, vegas
