DOES any one have URETHANE CONTROL ARM BUSHING THAT DON'T SQUEAK!!!
MY BUSHING ARE SO SQUEAKY !!! i just cant stand it any more just yester day i was at my friends sisters house borrowing a gps and when i was leaving( squeaking away ) she asks me "is that thing going to make it" plus in general it makes my truck sound like a piece of junk. so please if anyone has urethane bushing that don't squeak or even if they do please reply
From my understanding, all Urethane bushings will squeak at some point. I looked into this some time ago. Turns out even the Graphite impregnated Urethane squeaks at some point to. From what I have learned, too stop the squeaking. You must either do routine maintenance or mill some groves and holes in the bolts for greasing internally.
How long have you had your squeaky bushings installed?
you could go through the Control Arm, or you could do it in the same manner grease-able shackles are done.
Oh and check out this thread. You may be interested.
https://www.yotatech.com/forums/f15/squaw-ridge-pardoes-trail-august-27-28-2011-a-232331/
i couldn't open that thread or upload it fairytales and shaef is the marine grease real thick or something
plus one thing that almost stops the squeak is if you soak the bushing once a week(or two) with liquid wrench silicon spray but i'm just doing that temporarily
marine grease is waterproof and will not wash away as much. What did you originally lube them with during install and which brand? Energy or Prothane. I think I remember Prothane ones being noisier then Energy but it could be the other way around.
So far so good on my leaf spring energy bushings, forget how long ago I put them in but most of the lube that I used is what came with the bushing kit and then some Sta-Lube Marine grease on the non-greasable bolts.
xtreme i have the energy suspension bushings with the silicon grease provided in my a arms (the ones that squeak) but in the back i have downey offroad urethane bushings that have bearing rease and they dont squeak at all
FS[GreatLakes]: Toyota collection part out
88sasturbotoy
Jan 30, 2026 01:57 PM
FS[SouthEast]: Mercury Villager Fan & DCC Fan Controller
coryc85
Sep 9, 2015 06:24 AM
