85 22re Temp gauge issues after blown HG
I blew the HG in my truck(85 toy p/u w/22re). I replaced the timing chain, guides and tensioner while I had it torn down.
Now that I have it all back together and running, my temp gauge won't move. I took the T-stat out and tested it. It opened and closed like it should. I have the correct tension on the belt for the water pump. I did not replace the water pump b/c it was less than a year old.
The upper radiator hose (that leads from the t-stat housing) gets hot and is pressurized once the engine gets warm.
Anyone have any ideas on what would be the problem or cause the gauge to not work?
I was squeezing the upper rad hose when I was filling up the rad to get all 8.9 qts of fluid in it.
I also broke the connecttor housing for thermo switch#1. To get the connector to stay on the switch I had to use some elect tape. I planned on replacing the connector since its broke. Could I be getting a bad connection between the switch and connector causing the temp gauge to not read?
The broken connector would be my guess. Can you just crimp on a connector to fit over the terminal..kind of like a speaker wire. That what I had to do to sensor in the thermostat housing.
the1998sr5
15
Jul 14, 2020 08:35 PM
Poncho0206
Jul 10, 2015 06:21 PM
22re, 86, connection, gauge, hg, housing, sensor, tem, temp, temperature, test, testing, thermostat, thermoswitches, tiyota
