What is this Whine in my 3.0?
This sound is horrible. I have an aftermarket exhaust on now, and when idling, you can hear the whine over the exhaust. When sitting in the driver's seat revving the engine, you hear the whine over the exhaust.
(You can't hear the whine at first. Wait until I reposition the camera away from the fan and more towards the side of the engine bay. The video does perfect justice to the sound.)
Thanks to all that help!
http://www.youtube.com/watch?v=diNMqddzM4U
Last edited by dropzone; May 18, 2011 at 10:29 PM. Reason: eliminated double video link
As others have said, something in the front. Candidates include power steering pump, alternator, fan bracket idler, A/C idler, or as oldblue pointed out, could be upper or lower timing belt idler, or even the water pump. Best tool for finding something like that is a mechanics stethoscope. They're cheap, available at any discount auto parts store. They have a long metal rod that you hold against what you want to listen to, and you can hear real well what the bearings sound like. You'll hear noise even from good bearings, but if a bearing is bad it's real obvious as the noise is terrible. Obviously, you have to be very careful keep the stethoscope, loose clothing and hair away from the moving belts. Running belts can grab things with stunning suddenness and violence. If you don't hear anything from the bearings in the fan belt area, more probably a timing belt idler.
Check your P/S pump fluid level 1st. You do use Dexron-rated ATF in there, right?
scott90
Oct 4, 2015 09:21 AM
