22re Hesitation/Idle issues HELP!!!
Old May 16, 2011 | 01:43 PM
agoekler's Avatar
I bought my 93 toyota 2wd pickup 3 yrs ago and have never had a problem with it, only replaced the radiator when it cracked. When I was driving home one day, a thunderstorm hit and I drove under an overpass and onto the curb to avoid the hail, going through about 2 foot of water to do so. Since then, my truck has been hesitating under load, like it peaks out a 3k rmp and then rockets off after about 5 seconds. After about 10 mins of driving it runs like a dream. Also when I start it up warm it will idle rough at about 500 rpm, acting like a miss, but will quit after a couple minutes and idle at a smooth 800. I originally thought the fuel filter so I changed it, but it still does this. I'm at wits end and dont know where to start to look. PLEASE HELP!!!
Old May 16, 2011 | 03:04 PM
Gamma_Hugo's Avatar
you prob got hydro lock
Old May 16, 2011 | 06:57 PM
agoekler's Avatar
wouldnt hydrolock stop it dead in its tracks?
I pulled the plugs and didnt see any obvious signs of hydrolock, and ive been driving it for about 3 weeks like this. Im just getting sick of it hesitating and not having any power.
Old May 16, 2011 | 08:48 PM
Teuf's Avatar
Check the cap and rotor for water. Its not hydro locked.
Old May 16, 2011 | 11:26 PM
olharleyman's Avatar
I agree with Teuf but would also check the plug wires and see if you have one with a crack or the coil wire(run it at night and look for blue spark flying from the wires) and it/they are letting spark escape plus a full tune up if you have not done anything in 3 years would be a good idea no matter what.
Old May 17, 2011 | 10:27 PM
agoekler's Avatar
I pulled the cap and had a little moisture inside, also the o-ring was bad, sprayed it full of wd-40 and put cap back on, still hesitation at start of driving. will check wires for sparks tomorrow night.
Old May 18, 2011 | 05:40 AM
stucktoy's Avatar
I would check the o2 sensor and its plug you might be getting a false read from corosion or a bad o2.
Old May 18, 2011 | 07:33 AM
Mr.Utah's Avatar
This is probably your problem, view thread below and clean/fix your COR unit next to the glove compartment. YOU WILL BE AMAZED!
Thread by: mattaway https://www.yotatech.com/forums/f116...-fixed-179998/
Old May 18, 2011 | 12:13 PM
agoekler's Avatar
i ran a quick diagnostic and got codes 24 and 31, both pointing at the VAF and the IAT. I guess thats the problem.
Old May 18, 2011 | 04:57 PM
Mr.Utah's Avatar
Last time, try the COR as I posted earlier.
Old May 18, 2011 | 09:42 PM
Teuf's Avatar
And what does the CORE do. I have never heard it mentioned before regarding hesitation Etc.
Old May 19, 2011 | 03:33 AM
Mr.Utah's Avatar
Its an electrical relay for the fuel pump. They get corroded, then on a muggy or rainy day they short out; causing bucking and stalling. The symptoms mimic bad fuel pump or a clogged filter. If you have a 22re, Its worth checking out to prevent the problem.
Old May 19, 2011 | 09:58 AM
Teuf's Avatar
And its under the glove box, beside the glove box, below the glove box? I'll look today.
Old May 19, 2011 | 10:23 AM
agoekler's Avatar
I pulled it out and it looked brand new, both inside and out.
Old May 19, 2011 | 10:54 AM
Mr.Utah's Avatar
Check out mattaway post below,
Old May 19, 2011 | 11:59 AM
agoekler's Avatar
you pull the glovebox, and its on the right near the top, its pretty obvious. mine had 2 fuses with it too.
on another note, i pulled open the VAF meter and there were 2 contacts touching, i fixed those and reset the ecm and its not giving anymore codes, but still hesitates.
Old May 19, 2011 | 01:35 PM
Mr.Utah's Avatar
bump....I am out of ideas
Old May 19, 2011 | 03:30 PM
cman1's Avatar
mine does the exact same thing when i go through the car wash,drive it awhile,shut it off and start it again and its gone,WTH!!!.
bigjstang
Jun 2, 2025 03:56 PM
MO transplant
Apr 23, 2023 11:58 AM
mskalmus
May 28, 2017 07:51 AM
montanatruck
Feb 26, 2017 07:07 AM
PlayAwhile
Jul 20, 2015 11:36 AM
