General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
'85 Stereo Wiring ???'s
Old Mar 30, 2011 | 04:05 PM
Sleepr71's Avatar
Red face '85 Stereo Wiring ???'s
OK..I'm finally getting around to installing a head unit(Pioneer) in my 85 SR5 4x4 & guess what..(previous)owner has cut the plug off the harness. With wiring being my achilles heel I figured I'd post up & see if you guys can help out(&I'd rather not pay a stereo shop). Here's what I could determine(voltage wise) from the wires under there... in the Off-ACC-Run positions.
Red/Grn stripe..0.6v-12v-11.5v
Wht/Blk stripe..0-0-0
Blk/Wht stripe..0.1-0.1-0.1
Lt Grn/Blk stripe..0.2-0-0
Lt Grn/No stripe.. 0-0-0
Lt Grn/Rd stripe.. 0-0-0
Lt Grn/Yellow stripe.. 0-0-0
Dk Grn/No stripe..0-0-0.1
Soo..it appears the Red/Grn wire is POWER..(should it have 0.6v-OFF)? What should I use for a "signal" wire(to not lose presets every time the key is turned off? Maybe the Blk/Wht..since it shows 0.1v all the time? Which is Ground?Sorry..but it's been a LONG time since I've wired a stereo.Sleepr71.
Old Mar 30, 2011 | 07:52 PM
justin_4runner's Avatar
hope this helps
Old Mar 30, 2011 | 08:21 PM
weaselman's Avatar
do your wire match these ones??
i can tell you for sure that
Red/Grn stripe..0.6v-12v-11.5v this is you wire that gets hooked up to red
Wht/Blk stripe..0-0-0 this is ground, black on your head unit
Lt Grn/Blk stripe..0.2-0-0 front speaker ground
Lt Grn/No stripe.. 0-0-0 front speaker power
also, you are missing your constant 12volt power (yellow on your head unit)
the orange wire is for illumination (headlights) your wire might be a diff color... mine is an 87.
Old Mar 30, 2011 | 09:15 PM
4Crawler's Avatar
My '85 stereo wiring was pretty hacked up, I tried using it for a new radio but found it caused all sorts of issues with dash lights, parking lights, etc. that I abandoned it and rewired it all with new power and ground wires. Re-used the factory speaker wires that are easy to trace out.
Old Mar 31, 2011 | 01:18 PM
peow130's Avatar
I can take a picture of the back of my stock radio, and it has the wiring pinout on it.
If you want
jasonty
41
Dec 23, 2018 01:00 PM
r3dfish
54
May 16, 2016 10:31 PM
theking11863
Mar 19, 2016 09:36 PM
sanctfy
All Other Toyota Swaps
Sep 15, 2015 02:52 PM
Esibnitsud
Jul 30, 2015 08:19 PM
