General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
Any one using an amp to power 6x9 speakers?
Old Feb 27, 2011 | 04:32 PM
skoti89's Avatar
I just wired in my sub and amp. My amp is 250 watt two channel and it is desperately trying to power my MTX 12'' sub. It doesn't bump at all.
What I was thinking was to use that 250 watt little amp to power two 6x9 speakers that I was going to put in the middle interior panels. Then just buy a higher watt amp for the sub.
Any one tried it and liked it?
Old Feb 28, 2011 | 07:16 AM
Kody B.'s Avatar
i run an old 240 i think it is to my 6x9's and i like it but make sure that you get the noise supressor for it or else when you start you car up u will hear a whining in the backround
Old Apr 8, 2011 | 10:59 PM
83Stealth's Avatar
better have good 6x9's. i was going to do the same but i didn't like the sound. a little grumble from outside is nice. and you know the ladies like a vibrating seat. ha ha. rockin a 10".
Old Apr 9, 2011 | 07:40 PM
MAD MARK's Avatar
What brand name amp?
Whats the RMS rating on the amp?
What gauge wire running to the amp from battery?
Is the sub a DVC or Single?
Any 250 watt RMS amp (even wired single channel) should be able to push a MTX 12". I would check to make sure for a good ground and that the adjustments on the amp are in the correct setting.
Old Apr 9, 2011 | 08:42 PM
scottishb's Avatar
Where are you placing the sub? Placement is critical. What's the fuse rating on the amp?
Old Apr 10, 2011 | 02:24 AM
MAD MARK's Avatar
Fuse rating has nothing to do with it. Its either working or not.
Gauge of the power wire is important.
Forgot to ask if the amp is bridgeable go ahead and bridge it down and try that out.
Old Apr 10, 2011 | 02:44 AM
kevtek's Avatar
I run a 12" Kenwood swirl powered by a 250W RMS bridged alpine sub and two Sony 6x9s as rear speakers (and 6" alpine fronts) powered off a 52x4 jvc headunit and it sounds nice. Adjusting the crossover I can easily set the sub low enough that you can't hear it over the 6x9s. I'm running 8gauge power and ground wires. Bridge your amp if possible and check your crossover.
Old Apr 10, 2011 | 01:29 PM
scottishb's Avatar
Wow. Fuse rating tells a lot. Simply asking if the amp is really 250 watts. The fuse tells you that. If it has a cheesy 15A fuse, then the amp is not 250w, for instance. An amp with, say, a 30A fuse will power a 12" sub just fine. I'll stop there... whatever.
Old Apr 10, 2011 | 01:32 PM
scottishb's Avatar
wait... E=IR. There.
Old Apr 10, 2011 | 01:59 PM
sebastianholmes's Avatar
^^^ its V=IR....
Old Apr 11, 2011 | 04:52 AM
MAD MARK's Avatar
If I have a 125 watt amp powering 2 12" with a 60 AMP fuse am I over powering them?!?!?!?!?!?!
If I have a 1200.1 powering a 12" SVC sub with a 100 AMP fuse but I have 24 gauge wire, am I overpowering it?
R=V/I
I simply asked for what brand, the wire gauge, and RMS power. If he can answer that we can tell if its a good enough amp or not.
Old Apr 16, 2011 | 11:44 AM
scottishb's Avatar
Originally Posted by sebastianholmes
^^^ its V=IR....
Please Google "Ohm's Law"
E stands for voltage. Then comes the Power Law. That's P=IE. Come on, guys.
Old Apr 16, 2011 | 05:14 PM
MAD MARK's Avatar
Your both right, regardless your still arguing over nothing.
Apparently the OP doesnt really even care since he hasnt posted in awhile.
Old Apr 16, 2011 | 09:13 PM
skoti89's Avatar
sorry guys....forgot.
It is a sony 2 channel. not sure of any other specs...it is old.
I am powering it with a decent wiring kit from best buy that was like 30 bucks a couple years ago.
I am running it bridged. I just think the sub needs more power, it has a good sound, but it is massive(very heavy)
When I am sober enough, I will go and check it out tomorrow....lol
Old Apr 17, 2011 | 11:51 AM
scottishb's Avatar
An older Sony? That could be one of the nice ones from back in the day!
Old Apr 17, 2011 | 01:41 PM
skoti89's Avatar
its an xm-250 mosfet. i am running it bridged. i used to use it to run 2 12's and it was pitiful
Old Apr 17, 2011 | 07:01 PM
scottishb's Avatar
Oh, man. That's only 50wx2. Hook it up to your fronts!
Old Apr 17, 2011 | 07:11 PM
justin_4runner's Avatar
don't even bother with that amp go and find your self a 4 channel putting out at least 50 per channel. run one for mids and highs and another amp for subs....
80Truck
Oct 12, 2025 07:25 PM
mussy01
Dec 13, 2016 08:20 PM
coreyedwards7611
Jan 16, 2016 06:38 PM
Esibnitsud
Jul 30, 2015 08:19 PM
AkitaDog
Jul 27, 2015 02:38 PM
