decal removal complete...sorta
so after about a month of having just the bed done I finally had some time to remove the rest. I started running short of time so I still need to buff it out really good but it still looks good for now. I decided to keep the decals on the door and see how I like before I take them off. (I kinda like the look) I also put the canopy back on…it looks 100% better imo. what you guys think?
before canopy and before the decals were taken off...
before washing...
after...
before washing...
after...
i dunno if it's just me because i'm colorblind, but i don't see any difference in the decals from the before and after pics...
i've tried removing decals on past toyota and it is not the easiest thing to do and definitely leaves a color difference. i did mine with a heat gun but if i were to try it again i would definitely use a steamer instead and maybe try one of those decal removing rubber wheels for a buffer/grinder on the more difficult sections.
Mine were brittle after 21 years. After varios checmicals and finger strength I finally decided to use a hair dryer on high and keep it an inch from the decal ata an angle and I was able to peel it as I walked the hair dryer along. Heat...peal...move...heat...peal...move...repeat! Worked like a Charm!
thats pretty much what i did. if you pull at just the right angle the resin comes right off with the decal..and trust me going slo and doing it right the first time will save you twice the time later in getting it off.
heres a picture...
heres a picture...
i was washing my truck one day after a day in the mud and i use a pressure washer, i was like i dont like these decals and got closser and pressure washed them right off but it left the sticky stuff. i was also thinking about getting one of them rubber wheels.
You might want to try a solvent, like goof off.... then a buffing to blend it all together...
i used goof off but make sure you have a good clear coat. then best thing todo after that is wash then clay bar(well worth it) it gets all the smaller stuff off then wax.
One of these look like they would work nicely
http://www.youtube.com/watch?v=R7z48MmMhQ8
3m makes an "adhesive, wax and mark remover" that works excellent on vehicles. Similar to goof off but made specifically for use on vehicles. I've used it for removing decals and emblem tape. blow dryer to peel off Decal and then remover to clear residue is the safest way, works good too.
You can use starting fluid to remove the glue residue . Just use a plastic razor blade or something similar to scrap the glue off after it softens. It is not as bad on the paint as stronger cleaners .
1uzRunner
63
Nov 10, 2018 03:58 PM
Rickstwowheels
Sep 9, 2015 06:12 PM
86 87 4Runners
Sep 5, 2015 06:02 AM
86 87 4Runners
Sep 2, 2015 03:54 AM
