4runner cant hold idle and dies
Old Jan 12, 2011 | 10:51 PM
olympic42's Avatar
Hey all, I have a 1995 4runner v6 4wd. Yesterday i went to warm it up and i noticed after the truck was warmed up it had a tough time holding its idle. The truck woudl sputter and fart around 500 to 300 rpm. After driving it around town i notcied that it was lacking its already crummy power, all the windows and electronices were running dimmer and slower and at stop lights it would try and stall out on me. Any ideas or lists of things i can start looking at would be of great help, thanks.
Old Jan 12, 2011 | 11:29 PM
85toyman's Avatar
Battery or charging system. If everything that is electrical is running slower I would see how much of a charge your alternator is putting out. Most tire shops should check your system for free. See if your alternator is putting out the charge it should be, and then check your battery.
Old Jan 13, 2011 | 12:49 AM
TNRabbit's Avatar
Also, unplug the vacuum line going to the top of your EGR & see if that solves the problem. If so, your vacuum modulator valve is bad:
Old Jan 13, 2011 | 09:37 AM
olympic42's Avatar
thanks a bunch guys i will try both of these to see if any of them could be the problem and let you guys know whats up.
Old Jan 16, 2011 | 11:16 PM
olympic42's Avatar
Well no luck, i did the vaccum and EGR test nothing, my dad and i tested the batterey its fine, the alternator was tested and is fine any other suggestions? my dads friend mentioned something about a throttle response sensor or something i wasnt quite sure what he was talking about and i had to leave so i couldnt ask him about it. Does anybody know what im talking about with that?
Old Jan 17, 2011 | 10:08 AM
85toyman's Avatar
He is talking about the throttle position sensor. If you look at the back side of the throttle body you will see a black round sensor with a plug on it.
4crawler has a good write up on how to adjust the sensor. web site is 4crawler.com
Give it a try
MTLroadierunner
Jul 15, 2015 12:58 PM
Kalihi,HI
Jul 9, 2015 04:29 PM
Jnkml
Jul 6, 2015 01:20 PM
MTLroadierunner
Jul 6, 2015 12:17 PM
karbin
Jul 5, 2015 11:37 PM
