Sponsored by: CARiD
water pump just installed but its still overheats.....
Old Dec 27, 2010 | 09:38 AM
sq2124's Avatar
So i just got the new waterpump in and put coolant in it. Let is run for several minutes and then began to drive it. It started to makes this rev sound. it would rev and then release, it kept doing it and when i was driving. the heater was just blowing warm air. it began to slowly move to H. the overflow tank was boiling once it got to H. I checked the tubing and no external leaks i could find. the one thing i did notice tho is that my top rad hose was hot and my bottom rad hose was not. it was cold. Any Suggestions on what it could be??? Thanks.
Old Dec 27, 2010 | 09:46 AM
2Baloo's Avatar
From: beautiful sunny Southern Illinois. In the town of Carbondale
Did you bleed the coolant system of air?
Old Dec 27, 2010 | 11:05 AM
RobD's Avatar
X2 on the air bubble. You have to get the front end as high as possible to burp any air out of it. I'd try that first, then maybe investigate the thermostat.
Old Dec 27, 2010 | 12:23 PM
vincepower's Avatar
Yeah what the other guys said. I had a similar problem when i flushed my radiator.
Old Dec 27, 2010 | 12:34 PM
brian2sun's Avatar
If it's boiling in your overflow it may be a faulty radiator cap.
Old Dec 27, 2010 | 01:00 PM
buckwheat's Avatar
I had the same type of problem a while back, the radiator cap was junk
Old Dec 27, 2010 | 01:05 PM
runnermedic's Avatar
new cap and burp the engine,remember to use the correct antifreeze for toyota engines
Old Jan 1, 2011 | 02:51 PM
curtanderson's Avatar
leaking coolant from the front cover area
Got a call from my girlfriend that water/coolant is leaking from above the lower radiator hose on my 97 3.4L runner. Had a bad radiator 6 months back. Possible causes or starting points as I get home and dig into it?
Old Jan 1, 2011 | 03:12 PM
rworegon's Avatar
Please start a new thread. The search function will do wonders on this topic.
Old Mar 17, 2011 | 02:16 PM
sq2124's Avatar
i have a 94 toyota pickup 22re 2wd. Can you help me locate the bleeder?? usually i top of the radiator, start the truck and i can see airbubble come out. but today it was overheating in about 15 mins and the bottom hose was cold so i was gulping both hoses and the bottom hose started to warm up. the idle seemed high and i rember last time the idle drasticly went down. How do i know for sure that there is no air in the cooling system? i have no idea where the bleeder is on my 22re..
Old Mar 17, 2011 | 02:39 PM
83's Avatar
83
The way I bleed my cooling system is to let the truck run with the radiator cap off...
Old Mar 18, 2011 | 12:11 AM
wyoming9's Avatar
Red face
To make this simple I put a tee in the heater hose highest part in the cooling system.
Remove cap from Tee while filling radiator all the air is pushed out no more air pockets.
I did get the parts to put a bleeder screw in the tee but never did get around to doing it. To many projects not enough time.
Old Mar 18, 2011 | 06:39 AM
Team420's Avatar
Just park the rig facing up on a hill, pop the rad cap, fill, turn heat all the way up. and let run for 10-15 min... topping off as needed.
That usually burps my system just fine.
Sep 4, 2015 09:27 AM
thefishguy77
Jul 30, 2015 10:59 AM
TammyMarie
Jul 15, 2015 11:14 AM
Jonny246
Jul 12, 2015 04:51 AM
cars-guy
Jul 11, 2015 07:51 PM
