HELP stripped hub bolt
I just bought new warn hubs for my 92 toyota. I took the 6 bolts off the hubs i have now and i took off the 6 acorn bolts and removed the cover to the hubs. i tried to loosen the bolt thats in the center of the hub and it just kept spinning so i put the truck in 4 wheel and the bolt stopped spinning. i went to loosen the bolt that holds the hub in and it was already stripped. what should i do now? please help
The "gold" bolt/washer that is in the end of the axle?
The axle hole has stripped threads or the bolt has boogered up threads? You can drill and tap the hole or clean up the threads with a bottom tap and buy a new bolt.
:wabbit2:
:wabbit2:
Bolt Extractors
DRIVE 3/8"
CARTON QTY 1
REMOVES FRACTIONAL SIZE BOLTS 5/16"
REMOVES METRIC SIZE BOLTS 8mm
- When you are faced with a rounded-off, rusted-tight or painted-over bolt, bolt extractors will break it free
- Reverse spiral flutes are designed to bite down to provide maximum gripping power
- High carbon steel ensures longer life and greater durability
- Universal lobular design fits all types of fasteners
- 3/8" square drive for use with hand ratchets, impact wrenches, and air ratchets; hexagonal flats for use with flat wrench, pliers, adjustable wrench, sockets or VISE-GRIP locking pliers
DRIVE 3/8"
CARTON QTY 1
I'm not sure exactly what you mean. But, I'm pretty sure the answer is no.
There aren't any parts that are seperate from the hub locker body behind that bolt. The body comes off as one piece. Your new hub locker bodies should have all the required components. Nothing gets re-used, except the nuts/bolts/washers. AFAIK.
FS[SouthEast]: Aisin factory hubs, cleaned and lubed
carlspeed
Aug 23, 2015 02:59 PM
pyramid
Jul 30, 2015 10:05 AM
