replaced ground wire connector = more power
I replaced the crimp on connector that bolts to the block via a stud on the distributor side of the engine. My trucks doin wheelies now!!
ex·ag·ger·ate
1. To represent as greater than is actually the case; overstate
2. To enlarge or increase to an abnormal degree
but yeah you'd be surprised the kind of trouble bad grounds can cause; many people look right over it
now i just need to
1. leak down test (possible exhaust valve leak)
2. replace both cv axles
3. bleed brakes/ install rotors
4. fix center console cubby hinge
5. get a new windshield
6. investigate 4wd hi shaking
7. do the "big 3" upgrade, for fun. (I like working with wires)
fun stuff to keep me busy through the boring and rainy Washington winter
voiddweller
19
May 2, 2016 09:10 PM
Beavah
9
Nov 12, 2013 07:31 PM
