3.0 missing,poor idle,strong exhaust smell
Hello all,
need some help. i have a 89 1 ton dually yota with a flatbed auto trans 3.0 engine. it's missing at idle and i'm pretty sure it's flooding, has a really strong exhaust smell and sucks gas.
i replaced the plugs,wires and cap plus rotor button today and it didn't really help. the old plugs were black like gas flooding. i don't know where to look to fix the problem anyone have any ideas what it could be?
it starts good and all but it is sputtering and missing at idle and right off idle and sometimes when taking off it shakes when accelerating like it's flooding.
thanks
thanks
No, there is a temp sender that works your gauge. The ECT( engine coolent temp sensor) tells the ECM( computer) what your coolent temp is and uses this info to adjust your injector on time ,also has a hand in your cold start injector operation. The ECT is considerd a master sensor and controls many other aspects of engine operation.
Unbolt your CSI from the plenum, but leave the electrical connector and fuel line hooked up to it. Place the CSI in a jar and turn the ignition switch to on. Look at the CSI in the jar - if it is seeping fuel you more than likely just found your problem.
The CSI is supposed to spray briefly at start up, then quit. If if keeps seeping fuel, you wind up with a flooded condition, it runs crazy rich, barely holds idle and the exhaust smells like gas.
This is a really easy thing to rule in or out and thus a good place to start.
Wish I knew that when I had my 3.0 and it made it test as a gross polluter! Is it pretty common for that to go bad?
If you suspect its not opening, ( not your case) then you want to test it when its cold,
It should shut off right after starting 10 seconds or less. Warming it up is fine. You want to give the time switch enough time to heat up and turn the injector off. Then test it as described above.There are manuals for just about every year truck on this site. They will give you all the test procedures.
