Transmission swap
Old Nov 27, 2010 | 08:39 PM
Gordo's Avatar
Transmission swap
I have an 88 four runner 22RE. 5 spd. The current transmisssion is a w56c. It’s jumping out of first and second gear all the time and makes noise in every gear. I have a line on a low mileage G58 for a 22RE engine. Transmission only has 65K verifiable miles . My question is will my transfer case off the W56c bolt up to the G58 transmission?
Old Nov 27, 2010 | 08:49 PM
streetlancer's Avatar
Actually, considering your truck is an 88, it has a w56b transmission.
^That is a top shift & gear driven t/c
The g58 is chain driven, so i dont think it will fit
Check this page for more info:
http://www.4x4wire.com/toyota/faq/parts/
Old Nov 28, 2010 | 11:06 AM
Gordo's Avatar
According to the Marlin site the 88 has w56-c transmission. Just an FYI
Old Nov 28, 2010 | 06:50 PM
angrybob's Avatar
W56 has 21 splines on th shaft and the G58 has 26. They are not interchangeable. The question is whether or not the G58 trans + VF1A xfer case is the same length and have the same mounting at the cross member, etc. as the W56 + RF1A.
Heh - I would love to sell them to you but we would need to take some measurements. I do have an xfer case from a W56 that we could compare dimensions.
Old Nov 28, 2010 | 08:00 PM
Are you sure?
Well Look Again!!
Model Year Model Year
L43 1979-80 (20R) L45 1981-82 (22R)
L50 1981-82 (22R) L52 1983 (22R)
G52 1984 (22R) G54 1986-88 (22R)
G58 1989-95 (22R-E)
W56-A 1985 (22R-E) W56-B 1986-88 (22R-E)
W56-C 1989-91 (22R-E) W56-D 1992 (22R-E)
W56-E 1993-95 (22R-E) W59 1995-05 (2/3RZ-FE)
R151F 1986-87 (22R-TE) R150F 1988-95 (3VZ-E)
R150F 1995-05 (5VZ-FE)
^That was taken directly from his site. (marlincrawler transmission aplication table)
Easy way to settle it: just look if yours is top shift or forward shift.
Old Nov 29, 2010 | 04:39 AM
angrybob's Avatar
On second thought, my specific G58 setup wont work easily. I do not have a gear shift lever or the lever alum cover. Would have to bone yard those parts and would probably be a PITA.
Gimme a ring tonight if you want to discuss further.
Old Nov 29, 2010 | 04:29 PM
Gordo's Avatar
Decided to use the wrecking yard. Pick it up tomorrow. Gave me a 90 day warranty. Might be better than trying to make something work.
Old Nov 29, 2010 | 08:14 PM
Gordo's Avatar
Sure on the bushings. Replaced 3 weeks ago with the Marlin bushings
Liadrin
Apr 25, 2022 02:54 PM
mskalmus
May 28, 2017 07:51 AM
jjrbus
Jul 17, 2015 07:06 AM
Poncho0206
Jul 10, 2015 06:21 PM
madxman21
Jul 9, 2015 10:26 AM
