Info Please! replacing solenoid on A340H transmission
Old Nov 13, 2010 | 02:56 PM
93runnerguy's Avatar
Exclamation Info Please! replacing solenoid on A340H transmission
so i have a bad solenoid in my tranny that controls my 1st and 2nd gear, i have a replacment but i need to know which solenoid i actually need to take out, ive seen the picture of the valve body with all the differnt solenoids but i dont remember where i have seen it if anyone can post a link so i can check it out that would be greatly appreciated! Oh the tranny is a A340H automatic out of a 93 4runner
THANKS!
Old Nov 13, 2010 | 08:14 PM
MudHippy's Avatar
The FSM should be good enough to guide you through the process. Here's the automatic transmission section.
http://personal.utulsa.edu/~nathan-b...autotrans.html
Old Nov 28, 2010 | 11:22 AM
manyyotaman's Avatar
here is a link with some excellant transmission information as well as a picture I was just looking at of exactly what you asked.....
http://www.pirate4x4.com/forum/showthread.php?t=587521
Old Nov 28, 2010 | 04:36 PM
InternetRoadkill's Avatar
You might want to consider replacing all of them while you have it apart. If one's going bad, the others won't be far behind.
Old Nov 30, 2010 | 03:56 PM
4runnerx3's Avatar
Shift solenoids 1 and 2 work together in a pair. 1 on, 2 off is 1st, 1 off 2 on is second, both on is 3rd and both off is OD. So if one is not working, you would have two gears messing up.
smthwsn357
May 1, 2024 07:28 AM
icentropy
Sep 16, 2020 02:47 PM
mskalmus
May 28, 2017 07:51 AM
Jnkml
Jul 6, 2015 01:20 PM
MTLroadierunner
Jul 6, 2015 12:17 PM
