Sponsored by: CARiD
What kind of grease do you use in birfields?
Old Nov 8, 2010 | 09:20 PM
bytal's Avatar
What kind of grease do you use in birfields? Hopefully that's not too stupid of a question. Do you just use regular bearing grease?
Old Nov 8, 2010 | 10:21 PM
SpecialScottie's Avatar
Used heavy duty wheel bearing grease in mine and havent had any problems
Old Nov 9, 2010 | 03:36 AM
INFINITY's Avatar
moly is what the fsm states if i remember correctly
Old Nov 9, 2010 | 08:49 AM
Outsane's Avatar
AMSOIL Synthetic Polymeric Off-Road Grease
NLGI #2
5% Moly
http://www.amsoil.com/storefront/gpor2.aspx
I actually used a mix of NLGI #1 and #2 but I would have rather just used all #2
Old Nov 9, 2010 | 09:28 AM
Potomacduck's Avatar
NLGI #2
5% Moly
+1 on that. I use this grease for everything except wheel bearings. the Toyota manual states this should be used on the double cardan joint. I'f it's good enough for that, then that's good enough for me.
Old Nov 9, 2010 | 10:12 AM
4Crawler's Avatar
I used to fill mine with a small tube of CV joint grease, Sta-Lube brand as I recall.
Then pack the outside with some regular moly grease.
ashamsuddin
17
Jul 22, 2024 03:59 AM
kawazx636
Oct 6, 2021 03:03 PM
ladybugRC
458
Aug 21, 2020 10:41 AM
live4soccer7
May 11, 2016 06:52 PM
myotherrideisayoshi
Sep 29, 2015 05:41 AM
