HARRENSTEIN's 3.4 swap into '93 4runner
Old Nov 7, 2010 | 08:18 AM
HARRENSTEIN's Avatar
I "finished" my 3.4 swap a couple months ago and figured I would share some pictures.
Here is what I started with:
Old 3.0 with a bad connecting rod bearing:
New 3.4 with 111,000 miles:
New timing belt, water pump, valve cover gaskets, etc:
Paint! (Still holding up good)
Old Crossover:
New Crossover:
Engine in the truck:
New rims and tires:
Looks like a whole different 4runner:
I still need to finish up my EVAP stuff and battery tray. As well as get the OBDII port wired up.
Old Nov 7, 2010 | 10:31 AM
sam4runner's Avatar
Looks really good, Especially the engine paint.. Those duratracks look way good as well. Good work looks clean.
Old Nov 7, 2010 | 11:41 AM
MaK92-4RnR's Avatar
What crossover did you use?
Old Nov 7, 2010 | 12:46 PM
I built my own crossover. I just ordered some 2" tubing with 180 degree bends and cut and pieced them together. I had new flanges cut where I work on the plasma table. The tubing is from Hearthrob Exhaust here in Minnesota. I did the same thing for the rest of my exhaust.
Old Nov 7, 2010 | 01:00 PM
MKtaco_98's Avatar
Awesome Job Harrenstein really like the red block
Old Nov 10, 2010 | 09:34 AM
calipatient's Avatar
so its all 2inch from the manifold forward, but how wide did you go when you merged them at the last flange? 2-1/2"? ... 3"?
Old Nov 10, 2010 | 09:40 AM
super clean btw!
Old Nov 10, 2010 | 10:07 AM
Thanks for the comments. I still have some cleaning up to do under the hood. I'll try to get more pictures of that and more details on how I did things when I can.
As for the crossover.. It is 2" merged into 2.5" with a 5"x11"x18" steel baffled muffler. It was a tight sqeeze getting the big muffler in there and keep it up high. Right now I have it ending just before the rear axle and it is a little louder in the truck then I want. I finally have the more tubing to get the exhaust to the rear and I know that will help a lot.
If anyone has questions I will try to help as much as possible.
Old Nov 10, 2010 | 08:11 PM
theMonch's Avatar
X2. I thought I was working miracles with my rusty donor motor, but you really have dressed that terd up! I feel like I might have been slacking.
Old Nov 10, 2010 | 08:14 PM
ChefYota4x4's Avatar
Nice work, Harrenstein! Looks great and love the new tires look as well!
Old Nov 11, 2010 | 05:15 AM
Thanks. I love the tires myself. I dont get any road noise at all. Almost wishing I would have got 33's though.
I cleaned the block using a wire wheel that fit into a drill. Some of the tighter spots I had to use a die grinder and sanding wheel. Then used duplicolor engine paint.
And wouldn't ya know it... truck wouldnt start this morning. First real cold morning we've had so I'm not sure if that had something to do with it. It cranked and would fire every now and then but would not start. Then I noticed I had fuel that appeared to be leaking from between the manifold and crossover pipe flanges. I guess its time to get my OBDII port hooked up and read some codes.
Old Nov 15, 2010 | 09:21 AM
Well I dont know what was wrong with the truck but it started up Friday night and has been fine ever since. I'm guessing that I had or still have a loose wire somewhere. Got my OBDII port wired up as well and no codes and the datastream seemed to check out good.
Old Nov 15, 2010 | 05:58 PM
RobD's Avatar
If I had one piece of advice, and it's a little like closing the barn door after the horse gets out, but you should (have) put a flex joint on your crossover, somewhere between your two exhaust flanges. The expansion and contraction of your engine will be different from your crossover and you'll more than likely develop cracks near the flanges.
Old Nov 15, 2010 | 06:04 PM
Yeah I thought about putting a flex connector on the crossover but figured I would give this a shot. If it cracks I guess I'll just pull it back out and put a flex in.
Old Nov 15, 2010 | 06:47 PM
RobD's Avatar
I speak from experience.
And it's going to be a pain to fix.
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
mskalmus
May 28, 2017 07:51 AM
coryc85
Sep 9, 2015 06:24 AM
HRDC0R19
Jul 5, 2015 06:43 PM
