3vze wont start after timing belt change
I searched around and couldn't find anything to answer this question, but I just changed the timing belt on my 94 toyota pickup with 3vze, and in the process changed the transmission fluid/water pump. now when I try to start it, the starter motor engages and all the belts by the fan move, but it wont fire.
I did mess up the timing just before the new belt went on, but the cams are lined up correctly now.
any ideas what the problem could be? (or if I could have messed anything up with the recent work?)
EDIT: seems like it had no compression, any ideas?
Thanks,
Alex
Thanks,
Alex
I dont think it is, the notches were lined up correctly. Although the gears on the cams were different (had different marks on them). I am going to do a compression test when I can, it sounds like there is no compression now.
voiddweller
19
May 2, 2016 09:10 PM
FS[MidWest]: 1995 4Runner 5vz 4x4
vasinvictor
Jan 20, 2016 12:39 PM
infinityisfive
Jun 16, 2015 06:51 PM
