22R Dist. Wiring Issue
At random I am hearing a weird chirping/high pitch sound from the distributor and/or the 2 wires that go down to it. When this happens, my truck will not respond and eventually dies. First thing I did was clean up all the wiring with new connectors and heat shrink. Took a little drive and it happened again today. I am really not to sure what is going on here.
kinda sounds like the section that triggers pickup coil is going bad but hard to tell. have you had the dist. cap off to check the rotor etc etc in it? also try taking the dist out and check for play in the shaft.
EDITED TO CLARIFY THE PICKUP COIL PLEASE READ AGAIN
The coil is an MSD and it has maybe 1500 miles on it. I'll have to double check the connections there. I have not pulled the cap yet, but I am going to pick up a cap and rotor today and try that. What else should I be looking at in there?
no no not the ignition coil, the pickup coil inside the distributor.
when you pull the rotor off you can see 4 fins that are a part of the shaft that rotate to trigger the pickup coil, kinds sounds like they might be rubbing. could also be the rotor tip came loose somewhat and hitting the cap contacts as well. which is more likely the cause.
Missed the "pickup"
That is certainly a possibility. I am going to throw a new rotor in and cross my fingers, if that doesnt work I have a spare distributor that I'll throw in.
Thanks
Thanks
Had someone look under my hood when I tried to start it, and you could see the arching. The truck was running fine when it was cool, I think that by driving it for a little while it got hot enough and arched enough to make the truck miss, back fire, and sputter out. Of course it was a non Toyota part that failed, I should have started there.
sandyota
Feb 4, 2021 11:16 AM
glad ya got it fixed, how'd you end up finding it?
