Pre 84 Trucks 1st gen pickups
81 pickup wont charge battery
Old Sep 26, 2010 | 10:16 AM
shmitty's Avatar
I have and 81 pickup that wont charge the battery the truck has a new battery and i just installed a new alternator but its almost like the alternator isnt doin anything at all. Does anyone know if there is some kind of exterior regulator or maybe a fuse of some kind that could be blown???
Old Sep 26, 2010 | 10:47 AM
myyota's Avatar
You might have a bad voltage regulator, it mounted on the driver side inner fender.
Old Sep 26, 2010 | 10:52 AM
scottishb's Avatar
Check your grounds. Feel all connections for excess heat. A hot connection is a bad connection.
x2 on voltage regulator
Old Sep 26, 2010 | 06:38 PM
shmitty's Avatar
I just picked up a voltage regulator the old one looks to be in bad shape so ill jump on that tomorrow and double check all my connections, thanks for the tips guys
Old Oct 19, 2010 | 09:40 AM
hilux-1983's Avatar
Sooo, is it fixed?
Old Oct 20, 2010 | 08:03 AM
drokliss's Avatar
I had a fun one when I first got my rig, the guy had put an '86 alternator in it, and hacked together a pig tail connector. Must have been relatively recent, as it wasn't anywhere near wired up right and not charging the battery at all. I managed to use the connector from the external voltage regulator as a splice to hook up to the '81 wiring harness (with lots of help from an uncle).
Curious too...is it fixed?
sandyota
Feb 4, 2021 11:16 AM
Sep 4, 2015 09:27 AM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
skoti89
Jul 8, 2015 12:05 AM
colinmil
Jul 6, 2015 04:03 PM
