Found a coolant leak need help identifying part
The culprit is one of two old pinky sized hoses coming from the passenger side top rear of the engine (labeled "UT" from when the headgasket was replaced) to a double tipped screw in fitting just below the power steering pump.
Cant find it on a diagram. Any idea help on WTF this is? Im not sure if the fitting is leaking or the hoses.
Ill take a picture once it stops raining.
The only coolant leak you'd have on that side of the engine is from the u-shaped hose behind the plenum, passenger side. REMOVE YOUR HOOD; you'll thank me later. It's only 4 bolts & one of the easiest things you'll ever remove/reinstall on your truck~
You'll find it right here (yes, I realized it's a right hand drive pic, not my truck):
Here's the little bugger:
Avenged
Jul 9, 2015 07:55 AM
