How Do You Remove Water Spots
Does anyone have any good tips for removing water spots from the windows on my 4Runner ?. I worked on one window tonight and if you run you hand over the window it smooth and clean, but the water spots are still there. So any tips on what i could use to remove the spots ???.
Yeah i have heard the clay bar trick and the vinegar. When i detailed cars here in lewiston for rogers toyota we used acid. Just made sure to not use acid on the front window cuz it will make lines in the window!
i had really bad water spots. Used vinegar, glass spot cleaners, nothing worked.
Then one day when I was buffing my truck I just ran over the windows with my PC polisher and zaino Z-PC and the waterspots came off after a few passes. Soooo much better.
have you tried high pressure water????
i had water spots on my '96 dodge from May of this year...and i just went and washed them off...granted i had to scrub em with the brush at the carwash..then spray em off...they still came off lol
No updates yet, i have been told of a couple things to try, one is glass stove top cleaner and the other is called bar keepers friend. The stove top cleaner you can get just about any were, but i don`t know were to get the bar keepers friend from. (ive never heard of it before)
