How Do You Remove Water Spots
Old Sep 10, 2010 | 12:33 AM
myyota's Avatar
Does anyone have any good tips for removing water spots from the windows on my 4Runner ?. I worked on one window tonight and if you run you hand over the window it smooth and clean, but the water spots are still there. So any tips on what i could use to remove the spots ???.
Old Sep 10, 2010 | 04:29 AM
SoCal's Avatar
Clay bar or White vinegar, vinegar is a little old school the clay bar will work best. Just make sure you use the spray wax stuff with the clay bar.
Old Sep 10, 2010 | 06:34 AM
94toy4x4fever's Avatar
Yeah i have heard the clay bar trick and the vinegar. When i detailed cars here in lewiston for rogers toyota we used acid. Just made sure to not use acid on the front window cuz it will make lines in the window!
Old Sep 10, 2010 | 06:35 AM
4ever4running's Avatar
X3 on the clay bar. Not necessarily designed for glass but still works pretty well
CLR will take off water spots and the rust off the truck. lol
Old Sep 10, 2010 | 11:18 AM
myyota's Avatar
I will give the clay bar a try and hope it works.
Old Sep 10, 2010 | 11:35 AM
myyota's Avatar
Ok, i just went out and tried the clay bar on the window, and it didn`t do anything, any more ideas.
Old Sep 10, 2010 | 11:40 AM
camo31_10.50's Avatar
have you tried good ole fashioned Dawn Soap and HOT water?
2800PSI of hot water and Dawn soap gets anything off the vehicle pretty easily..
Old Sep 10, 2010 | 12:02 PM
myyota's Avatar
I just tried some dishwasher soap and a SOS soap pad and that didn`t work either.
Old Sep 10, 2010 | 12:35 PM
FORANA's Avatar
i had really bad water spots. Used vinegar, glass spot cleaners, nothing worked.
Then one day when I was buffing my truck I just ran over the windows with my PC polisher and zaino Z-PC and the waterspots came off after a few passes. Soooo much better.
Old Sep 10, 2010 | 12:51 PM
don't scratch up the window dude.......
Old Sep 10, 2010 | 12:57 PM
myyota's Avatar
Yea, i was careful and just tried it in a small spot. I swear these water spots are laughing at me. I might try some CLR next and see if that does anything.
Old Sep 10, 2010 | 01:00 PM
have you tried high pressure water????
i had water spots on my '96 dodge from May of this year...and i just went and washed them off...granted i had to scrub em with the brush at the carwash..then spray em off...they still came off lol
Old Sep 10, 2010 | 02:07 PM
myyota's Avatar
Hi presure water didn`t do anything.
Old Sep 11, 2010 | 11:12 AM
maistroyoda's Avatar
How bout extra fine 0000 steel wool? I use it on aquarium glass and it works great!
Old Sep 11, 2010 | 11:23 AM
MortonPhotographic's Avatar
If it is that hard I would try car wax or paint plishing compound
Old Sep 11, 2010 | 02:02 PM
John LTD's Avatar
Best thing I have found is glass stove-top cleaner it worked wonders for my glass. Try to avoid getting it on the black window trim though.
Old Sep 15, 2010 | 05:55 AM
If the clay bar didn't work then I would try CLR next. Just be careful because it is strong stuff and I don't know if it will do anything to paint...
Old Sep 20, 2010 | 02:36 PM
RMA's Avatar
RMA
any updates . myyota .. i have the same problem .. i think im gonna try the steel weel .. only because i have some right now. if that dont work ill be trying the stove glass cleaner.
Old Sep 20, 2010 | 10:08 PM
myyota's Avatar
No updates yet, i have been told of a couple things to try, one is glass stove top cleaner and the other is called bar keepers friend. The stove top cleaner you can get just about any were, but i don`t know were to get the bar keepers friend from. (ive never heard of it before)
