I need a pic of the bottom of a 22re intake manifold
I am installing a "new" engine in an 89 pickup and I can't get the coolant bypass tube done. It comes out of the back of the left side top of the timing chain cover and it has two branches. I found where the small branch goes but the large hose goes somewhere under the intake manifold. Of course the manifold and plenum and all the snakes of tubing are now done, so I have to feel around under the intake manifold to find out where to put that hose. It would be really helpful to see a diagram or pic ot the underside of that manifold, so I know what I am doing with that hose.
Polis.
Polis.
Look up iamsuperbleeder in the member list and find his thread on rebuilding a 22re he took lots of pic's. Helped me out when I swapped my 22 for a fresh 22. Also with you having it in the easiest way to get to it is with the wheel off and the tube also goes behind the fuel filter at the top just a heads up if you have not done that already.
FS[GreatLakes]: 22RE performance and stock parts (pic heavy)
May 20, 2016 10:27 AM
