vibration 45-60 mph
Old Aug 16, 2010 | 03:37 PM
zwhiz's Avatar
From: where the left turn should have been taken, NM
vibration 45-60 mph
88 truck
thought it was my rear driveshaft ujoint at the t case but i replaced it and the vibration got a little better but not much...i jacked up the front end and didn't find anything to be abnormaly loose or anything... stumped... could it have something to do with the t bars being cranked up?
Old Aug 16, 2010 | 04:54 PM
88redyota4x4's Avatar
u might wana try greasing all of the fittings in the drive line, i had the same problem a lil while back, and i just greased everything and the vibration went away in like 2 days, i guess it just really needed to be greased, hahaha
Old Aug 16, 2010 | 04:57 PM
xxxtreme22r's Avatar
it can, if you never had the truck re-aligned afterwords.
as a side note, don't you have to re-balance a driveshaft after installing new u-joints?
Old Aug 16, 2010 | 06:02 PM
Yotafisher's Avatar
I cranked my torsion bars and it didn't make any difference in vibration. When I changed tires however (used), I got a strong vibe from just about the same speed...45-60.
Old Aug 16, 2010 | 06:30 PM
BrianJE's Avatar
sounds like a bad tire to me.
Old Aug 16, 2010 | 07:25 PM
kawasakimoto_7's Avatar
what brian said could be it, and it could be your tires are out of balance.. id start with getting your tires re ballanced its cheap and easy. i bet you it will help a lot
Old Aug 16, 2010 | 11:54 PM
Lysmachia's Avatar
rebalance tires and get your driveshaft re-balanced too. The weight on it, very likley could have been stripped off while wheeling... Did you hit your driveshaft recently? That can do it too...
Old Aug 17, 2010 | 01:04 AM
yoterr's Avatar
ur hubs still locked in
Flightguy
Oct 2, 2015 05:34 PM
kbpickens
Oct 2, 2015 03:37 PM
hiluxinargentina
Sep 30, 2015 05:51 PM
JPV
Sep 28, 2015 03:15 PM
Odin
Sep 26, 2015 06:56 PM
