V6 Diff won't fit
V6 Diff won't fit
I bought a V6 third member with an ARB locker in it for my 85 4runner assuming that it would drop in to my 4cyl housing. The 3rd member won't fit into the axle housing. The ring gear makes it, but the sides don't. Should I trim the housing and then assume everything will fit or do I need to switch the locker and ring and pinion to my 4cyl diff using a bearing kit for it? Thanks, Austin
When i bought the high pinion third member with an ARB from marlin crawler it was a very tight fit when i went to install it, i didn`t have to trim anything to get it in, i kind of had to work it side to side and up and down and it finally slipped into the housing.
priest16
15
Aug 6, 2015 07:43 AM
FS[GreatLakes]: Wanted: 4.88 front diff, rear 8'' 4.88
jaretstuff
Aug 4, 2015 02:08 PM
yourrealdad
Jul 29, 2015 11:08 AM
Steven.m.paulk
Jul 24, 2015 01:44 PM
scottyg486
Jul 19, 2015 05:34 PM
