Temp Gauge Jumpy....
Old Jul 12, 2010 | 07:04 PM
simpsoap's Avatar
Lately, for about a month or so (maybe longer) my temp gauge has been really jumpy in my '95 4Runner 3.0. I first attempted to replace the thermostat with a 180 degree one from the dealership curious to know if the one I picked up from AutoZone was faulty. I ran the truck, and bleed the system, and I'm almost certain there is no air in the system.
I did a search earlier today and saw that people had suggested checking the connections on the Water Temp Sender and the Engine Coolant Temp Sender. All the connections look good and I didn't see anything unusual. Is there a way to test these sensors before I buy new sensors?
I've noticed that sometimes the coolant may be boiling when I get home after a drive as well, but I have no other issues and had the heads machined and replaced head gaskets and everything else late last year. All of this has just recently started.
TIA!
Andy
Old Jul 12, 2010 | 07:08 PM
85gijunk4x4's Avatar
my guesses would be a stuck thermostat or bad sending units...if everything seems okay, then maybe its the guage itself
Old Jul 12, 2010 | 07:10 PM
PismoJoe's Avatar
Download the FSM for your truck Here
It has in detail how to test resistance of the temp gauge sender, and how to check the actual gauge itself.
Old Jul 12, 2010 | 07:16 PM
simpsoap's Avatar
I already have downloaded the manual, but couldn't find anything in there in regards to testing the resistance or the gauge itself. Could you point me to the correct area? Maybe i'm missing something....
Andy
Old Jul 12, 2010 | 08:05 PM
PismoJoe's Avatar
http://ncttora.com/fsm/1990-1995_4Rn...emci/eng3r.pdf
Page 6 is for the ECT, engine coolant temp sensor, not very familiar with the 3vze except for there is 2 sensors
Originally Posted by thook
On the 3.0, the sending unit is on the "back" of the manifold next the to temp sensor tucked almost under the plenum. Tricky to get to. Both are to the driver side of the heater hose. The closest being the sending unit. To the left of the heater hose, is the cold start injector time switch.
I promise you its in the FSM lol just dig around
Old Jul 13, 2010 | 05:34 PM
simpsoap's Avatar
Well after using contact cleaner and cleaning both the connections on the back near the firewall on the 3.0, I was able to drive the truck today and put about 75 miles on it. The temp gauge performed as expected and didn't jump at all. Maybe the connections were dirty, or maybe something was just loose and not seated properly. I'll continue to monitor.
Thanks for all the help!
Andy
Old Jul 13, 2010 | 06:33 PM
angrydogtattoo's Avatar
glad that fixed it, I was going to say, hope its not a HG!
ashamsuddin
17
Jul 22, 2024 03:59 AM
Jdgarrison
Oct 1, 2015 05:22 PM
bradahman
Oct 1, 2015 09:24 AM
Matthew Perez
Sep 28, 2015 05:43 PM
rmill05
Sep 27, 2015 01:43 PM
