chevy 4.3v6 wiring questions
hi, i have a 90' toy 4x4 ex-cab pickup with a 4" suspension lift and a 3" body lift, put a chevy 4.3v6tbi out of a 92' chevy blazer vin z complete with ecu and wiring harness, and would like to ask a few questions about wiring.
Search Pirate4x4. Plenty of information. FYI, I'm also doing the conversion on my 94 4Runner and my 4.3 is out of a 92 Blazer vin z. All you need it like 5 wires to run the factory harness. Search Pirate and you will find the wiring schematic.
James
James
I have never been able to find much for wiring. But the best thing i have heard about it is to run 2 ECUs.
Here is the pirate link btw. http://pirate4x4.com/forum/showthrea...chevy+swap+faq
This is also a helpful link too. Doesnt help with wiring though, but still good to read though. I had to copy and paste it into a word doc to read it normally.
http://www.off-road.com/trucks-4x4/t...ion-18314.html
hey thanks, i found a ton of info on pirate and have already started the wiring process, it is not my favorite part but i get the just of it. i just got the 92 4.3 from the engine shop, bored .040 over .010 off mains and rods new stock cam and lifters remanufactured heads all stock fully balanced rotating assembly can't wait to get finished, will post picks in next couple days. again thanks for the help.
I’m putting a 2003 4.3 in my 85/86 Toyota extra cab having bit of problem locating the wire for the Toyota temp going to the gage and the check engine light , about to go to back of the instrument cluster if all else fails
hi, if you are like me and i hope not, i cut all the wires on toyota in engine compartment, and i have to do the same thing, i have to pull dash out to make sure i get the right oil and temp wires, fuel pump wires, and starter wire. good luck, i think that is what you will have to do. not for the weary is it.
No what I did was buy the little tool to remove unneeded wires from the Toyota loom. I identified wires like oil pressure, temp starter ac and the neutral start switch and the 4wheel drive wire. Still chasing the temp and the check engine wires. Going to pull the cluster and back trace those in the am. For the fuel pump I converted the Toyota tank to accept the Chevy pump asmembly using the howl stand alone harness and computer that was flashed to remove the security crap. Engines out of and 2003 astro van so had to keep all Chevy smog parts as I am in so cal
i got the toy running, it runs great and sounds great, my only thing is when engine off and key on run the fuel pump will cycle when brake is pushed, headlight switch turned on, wiper turned on, 4-way flasher turned on. i tried separating ground but didn't fix problem, i have the gm blazer fuel pump in tank, any ideas. thanks by the way 2doorrunner your progress looks very good, good craftsmanship
the1998sr5
15
Jul 14, 2020 08:35 PM
icentropy
Jul 14, 2015 10:23 AM
88yodabasket
Jul 13, 2015 01:32 PM
skoti89
Jul 6, 2015 07:45 PM
