Custom coil lift 4-5" ???
Old Jun 29, 2010 | 06:11 PM
joevanvliet's Avatar
Hey I Just installed a 4" IFS lift and I've still got my LC coils in the back. I was going to either get coil spacers or new shocks for a 4-5" lift.
My question is would I need to fabricate some 4" drop brackets for the 2 sets of arms that hold the axle in place (similar to the procomp lift that Ive seen) ??
Has anyone else done this and left it alone with no added brackets? BTW I have some 4" drop brackets already for the ARB, and the panhard drop and lspv bracket.
Old Jun 29, 2010 | 07:20 PM
conrad's Avatar
Those are called Torque Rods (or Torque Arms). Yes, you will need a bracket to extend them, if that's what you are referring to. Even though I don't like recommending NWOR, they may be the only place that has what you need. Scroll down on the link and you'll see it. Even though it's only listed for 79-15 trucks, I'm fairly sure it will work for your 4Runner. Call them to make sure
http://www.northwestoffroad.com/part...omponents.html
That's the only solution I can think of. Other folks might know better...
Good luck.
Old Jun 30, 2010 | 08:37 AM
cootees's Avatar
Theoretically you should either use the brackets or extend the arms.
You could probably get by without it but your axle placement will be off so it is recommended to take care of the issue.
Flying91
45
Apr 11, 2024 04:39 PM
Sep 4, 2015 09:27 AM
Ernie217
Aug 14, 2015 05:25 AM
Numberonedad6
Jul 30, 2015 07:10 PM
Vargntucson
Jul 4, 2015 12:15 PM
