Pre 84 Trucks 1st gen pickups
22r only running off battery
Old Jun 7, 2010 | 01:14 PM
ktown808's Avatar
ok truck wont charge, so i replaced the alternator and i still have the same problem, the battery is only reading 12.3 volts while running so i tool in the new alternator to have it bench tested and they said its fine. so i got a new voltage regulator in my truck but my question is would my voltage regulator keep my truck from charging
Old Jun 7, 2010 | 01:40 PM
swampfox's Avatar
yes it could keep it from charging. also check for corrosion and loose connections.
Old Jun 7, 2010 | 04:41 PM
slacker's Avatar
yep .. as above mentioned , check for salt corrosion on your connectors as well , as you are close to the ocean .. dialectricgrease on your connectors is a real good thing ! will halp prevent corrosion
Old Jun 7, 2010 | 06:25 PM
ktown808's Avatar
ok thanks, i just cleaned all of the connections and checked the grounds related to the alternator but still no luck, im pretty close to taking it in to a shop and have them deal with it because its just getting irritating. also if you remove the positive battery cable from the battery with the engine running should your engine stay on. I read that you can do that as a test to check your alternator and i have done that before on my old ford exploder and it ran fine without the battery and just off the alternator. If you got any ideas just throw em out there im all ears. thanks fellow yota owners
Old Jun 7, 2010 | 09:51 PM
zwhiz's Avatar
From: where the left turn should have been taken, NM
i had the exact same problem after i changed my alt and votage reg. once i changed all of the connections to the battery it worked better...
Old Jun 10, 2010 | 10:18 AM
ktown808's Avatar
ok guys got it all squared away so i guess it was a bad alternator. i guess when i first replaced it i should of changed the voltage regulator also but since i didnt it probably fried the alternator so i picked up a voltage regulator and a swapped the alternators and my truck is putting out 14.5 volts which looks very good to me, thanks for the help guys aloha
sandyota
Feb 4, 2021 11:16 AM
87blyota
Jul 10, 2015 04:31 AM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
skoti89
Jul 8, 2015 12:05 AM
colinmil
Jul 6, 2015 04:03 PM
