Tach Cluster swap, no coolant gauge now?
Liek it says. I swapped it in and everything worked! no tach tracer wire needed. Oil worked as soon as i got the correct sender.
One funny thing is that the coolant temp gauge looks normal, but after a few minutes just jumps from the bottom to the middle of the gauge. When i shut it off, and turn it back on, the same thing happens, just jumps to the middle. If i let it sit till its cool, or overnight, it goes back to the bottom again.
Before with my speedo/gas/coolant cluster, my coolant gauge worked perfectly. I know theres a difference in the oil pressure sender, but is there a difference in the coolant temp sensor as well? And seeing as it worked before, are the two temperature gauges interchangeable between clusters if i take them apart?
anyone ahve some ideas?
you can find a wiring diagram on this link:
http://ncttora.com/fsm/index.html
sounds like you just missed hooking up a wire
the1998sr5
15
Jul 14, 2020 08:35 PM
Poncho0206
Jul 10, 2015 06:21 PM
