Last edit by: IB Advertising
Browse all: Toyota 4Runner Brake Guides
- Toyota 4Runner 1996-2002: Brake Modifications
Overview of popular modifications to help you customize your 4Runner.
2000 4Runner Tundra brake upgrade
Okay, first off I do know how to use the search feature! I still can't find a simple answer. I have a lifted, supercharged 2000 4Runner that is in need of front brakes. I would like to do the Tundra conversion. I am currently running 17in Tundra wheels and 295 Nittos. I am looking for brands, part numbers, web sites, best prices, year Tundra stuff, etc. I am assuming with the 17in wheels i can use the larger calipers but maybe I am wrong. I would like this to be as bolt on as possible. Since I am already breaking the seal with new calipers, what is a good source for high quality front brake lines? i know you guys have all the answers. Please help me out. What brake brand, caliper brand, rotors, etc. I know a bunch of you have been through this so please help another 4Runner addict out. I value all of your advice!!
I thank you all in advance,
Rob Primavera
Rob Primavera
Searcchhhhh. Search big tundra brakes
https://www.yotatech.com/forums/f2/b...4runner-74601/
Then buy calipers, either junkyard, tundra solutions, or at a parts store reman or new. Then you need tundra rotors, they are all the same. I got all my stuff for an 02 tundra.
your stock brake lines with thread right in if you don't kink or strip them.
just did this to my 2k runner.
I got the loaded calipers at NAPA for $115 a piece. they took back my old/core no problems. I went with brembo slotted rotors, paid $100 a piece for them.
one of the easiest mods Ive ever done, about 1 hour from wheels up to brake test.
the braking is solid, no shimmy and no fade. should have done this years ago.
the only thing I can think of as being a drawback.......it almost feels like I lost some acceleration, the only thing I can think of is the increased mass of the rotor may be slowing me down just a touch, as they are not dragging.
I've been battling with the sloppy feeling pedal after the Tundra brake upgrade and I haven't found any official solution posted on line, so here is my fix to all of you dealing with a sloppy pedal after installing the larger Tundra calipers (231mm?)
I have a 2000 4runner 5spd manual, and I did the Tundra brake upgrade. The result was disappointing in the sense that my pedal travel increased, almost as if I had air in the lines, but I know I didn't. Because I used the larger 231 calipers, the stock 1" master cylinder was not sufficient. I found out that the last generation of T100 trucks, I believe 97,98 used a 1 1/16" bore master cylinder. I had to get a vacuum booster from a T100 to hook it up (because the master cylinder has 4 hose bolt pattern, instead of 2), but the result is a much firmer pedal - perfect!
How are they doing now and where did you get the parts!?
A simple search on amazon turned up the right part:
And I think this is the correct booster:
don't forget to buy a new gasket that would go between the booster and master cyl.
Ok awesome!
Brakes are doing great! You don't want to use the tundra master cylinder, it's only 13/16" bore size. You want a bore size of 1 1/16". The only master cylinder I found that was the right size was the T100 master cylinder.
Amazon.com: Centric 130.44722 Brake Master Cylinder: Automotive
Amazon.com: Centric Parts 160.88801 Power Brake Unit: Automotive
No sorry - you'll have to contact the toyota dealer to get the gasket - i'm not sure where to find it online , but I'm sure if you look you will find it. Let me know how it goes! Where are you located?
Thanks bud! I'll do a little research to find out. I'm in Colorado at the moment
Brake Booster Upgrade
"Brakes are doing great! You don't want to use the tundra master cylinder, it's only 13/16" bore size. You want a bore size of 1 1/16". The only master cylinder I found that was the right size was the T100 master cylinder."
I'm looking into doing this upgrade because I've noticed my power brake booster starting to fail. I have ABS on my 2000 4Runner but all I see is non-ABS for the 97/98 T100 power brake booster. Same deal on most of the master cylinders. Anybody know if I can put a non-ABS booster and master on my truck or non-ABS booster with an ABS master cylinder without any problems?
Jun 1, 2021 01:51 PM
Avenged
Jul 9, 2015 07:55 AM
Jnkml
Jul 6, 2015 01:20 PM
Suprarossa
Jul 6, 2015 05:21 AM
