Sleepingciv's 1993 yota pick up
Old May 23, 2010 | 05:45 PM
sleepingciv's Avatar
Well it not much to look at right now. But i traded a pos blazer for this and 300.00 lol
Haven done much to it really besides clean it alot lol.
I went south with my truck unlike most of you who have risin there truck.
But here she is
Old May 23, 2010 | 05:47 PM
Ill add some more in a bit
Old May 23, 2010 | 05:54 PM
toyospearo's Avatar
Looking good so far!
Old May 23, 2010 | 05:55 PM
thanks guys uploading more pics as we speak, well i type lol
Old May 23, 2010 | 06:03 PM
took all this crap off lol
6x8s in the dash now
Old May 23, 2010 | 06:21 PM
found this lol
Old May 23, 2010 | 06:25 PM
took these out
added the 4 inch blocks
and did this
Old May 23, 2010 | 10:29 PM
Old May 24, 2010 | 06:27 PM
started to paint frame today. its only temp till i get the product i want
Old May 24, 2010 | 11:10 PM
well it finally cooled down some so i finished the rear of the frame. i missed a few spots though lol o well
and did some more bay work
can u see the changes???
Old May 25, 2010 | 01:26 PM
graduatedpine's Avatar
Suscribed
Old May 26, 2010 | 01:46 AM
well did some more tonight. I figured since i tucked a little harness, i should it do it all lol
so started in the cab bla bla bla
and i always had this smell when i turned the heat on lol well som bitch look at this lol
this is what fell out of the blow motor housing lol
and this was still left in there with the pile on the floor
then started the tuck if ya look at the pervious pics you should be able to notice what i have done
inside after engine harness was ran in
still need to install fuse box and crap for headlights ect ect
and relocate battery to the bed
Old May 26, 2010 | 02:05 AM
adamsbro1's Avatar
I'm a 4x4 guy myself but it is nice to see a yota get cared for regardless plus I'm sure there are quite a few people on here who would enjoy a good 2wd build...... Down not up right lol!!!
Old May 26, 2010 | 03:28 PM
Thanks, ya I feel a little outta place here with all the 4x4s lol
Old May 27, 2010 | 01:06 AM
stupid bandwidth lol
good thing i have 2 accounts lol
anyway
the wire tuck is 99% dont need to run battery about it.
for those that havent seen the before pics and cant now until pics are working again here is a stock pic
here some during pics
need to place the fuse box, and the red wires ya see are for the ecu, i just moved them outta the way. but ya all wires are ran in this pic
here is the 2 harnesses . one was in the fender well already but i need it out to remove wire, and the other one was the stock one inside the engine bay that wrapped all the way around the front to the drivers fuse box
here is the harness ran and of course it stopped about middle of truck and it need to get to the drivers side fuse box lol
so
and the part i cut off and ran into the fuse box on the drivers side
all soldered and heat shrinked and taped/loomed, and i ended up moving that ground incase your wondering
check the bronze rimz yooo lol
and the white colored cables you see there coming from the black tape each hold 4 wires
there only like 16 wires that needed extended lol
and this is where its at now dirty and tucked, and some stuff moved/deleted
Old May 31, 2010 | 11:27 PM
well i had a run in with the truck the coil ended up going bad somehow so that was a set back
anyway here are some more pics
Got this stuff today.
But the damn knob dont fit lol
and some daytime pics
and starting to get put together
here is a pic of the harnesses ran in the pass fender , and yes i put the fender cover back in lol
now finding a new home for the fuse box
only seen one place for it to go.
had to remove the mounting ear
then this ear
and this gromet was perfect for the power wire out of the fuse box
8 gauge wire ran into it. show later where it goes
no to connect the 2
all soldered up and in its new home now
Old May 31, 2010 | 11:30 PM
got bored lol need some 22s
and these are from tonight
ok well got the damn harness back n the truck lol freaking stupid coil lol
anywho i think they bay is o i say 80% done now. need to fill some holes and paint some rusted ass brackets, and few other small things
check the new oil dipstick lol it was a last minute idea as i was smoking a cig and seen the baggy full of shells lol
should start to look better with a bath and some paint. like i said need to do a few more things yet in there
went ahead and relocated the battery to the rear also
this is a brass ground distro block. used it for the power lol i only covered in in cacse a rock or something hit it.
i was running wire and got to the back of the cab and seen this little **** eating a june bug lol
i hate spiders lol
lol after i killed that thing i ran the rest of the wire
and the bat is not going here its temp till i get the bed on
Old Jun 12, 2010 | 02:19 PM
uhgg damn bandwidth lol
more crap removed lol
and made one of the firewall/fender wall plugs
50 cals
Charecter1
Nov 6, 2023 10:08 AM
Colington
Mar 8, 2020 09:51 AM
young buck
18
Aug 27, 2018 02:40 PM
yourrealdad
Jul 21, 2015 11:13 AM
PlayAwhile
Jul 20, 2015 11:36 AM
