Intermitent Charge/Brake warning light
Ok so I have a 1988 4 runner with a 22-REC. I have been having an intermitent charging problem. My charge(batt.) light and Brake (e brake light) will both come on at the same time when this happens I am not charging. Sometimes it will light up right when I start the truck other times it will be while I am driving. It will clear up sometimes while I am driving and sometimes it wont.
I am pretty sure there is a short somewhere, has anybody had this happen to them?any ideas as to where I should look for the short first? Secondly is it common for the ebrake light to light up when the alternator fails?
Thank you in advance
it could be a ground issue at your alt. but that usually doesn't just "occur". but alt failure does occur when it wears out over time.
head into an auto parts store and have them test that alt for free. if it's bad, rebuild that alt. last one i sent out cost $80 to re-do. and i know it won't fail in a year like an autozone part. or of course, you can DIY like Hil suggested.
and yes, other "idiot" lights will come on with the ALT light to catch your attention. usually the brake lite. (in my LS400 it was the low coolant light. ?)
good luck
Tj
good luck
Tj
I am really leaning towards a short...I have never seen an alt. stop and start working so many times. 15 + plus times it has gone out only to start charging again.
and thx for the replies.
Kanyonkritter my 90 4Runner alternator took 6 months to completely die.It started in december bitter cold temps,brake/battery lights came on,new battery wouldnt charge.After warming up lights went off and volts on gauge shot up.Steadily got worse blinking on and off,some days alt. would charge some days it wouldnt.Last two weeks it refused to charge and lights stayed on all the time.I went to orielly and autozone both confirmed it was dead.Bought reman. Duralast with lifetime warranty for 140$ yesterday,installed it myself.Now it charges perfect lights havent come on.Ive already driven 125 miles.
Have 86 22RET with Alt, Brake and Turbo lights on. Suspect same issue. Took noisy alt in and except for bad bearing tested OK. Bought replacement but still have lights issue. Have pulled all fuses and cannot find any issue. Some other reading seems to logically point to a shared ckt issue and now thinking it is a poor ground. Have a typical wiring diagram but ommitted block right in middle of the connect between all lights is undefined. Wondering if anyone has a specific wiring dia? Will try to post any soln. thx
x2, it happened to me also, the lights would come on for a split second every now and then, then after a while it got worse then the lights were on all the time, and i had to charge my truck every day and let it run off the battery. just changed my alt the other day and now no problem at all
Had the same issue. The wire harness on the back of the alt was nasty. Frayed wires touching the side of the block shorting out. You can extract the wires and recreimp them and basically rebuild the harness. Pretty easy once you get it out. Also worth having the alt tested once pulled.
ok so the same problem is back......I never did change the alt. and honestly cant remember what I did to fix it. Its a little different now though. At idle the warning lights are not on slightly above idle the lights come on and stays light through the whole RPM range but the alt. is charging my battery.
battery and brake light problem
Had the same problem with battery and brake light coming on, every couple of months. When it would come on, that would let me know that the next time I tried to start the truck, I would need a jump. Changed battery, alternator, coil, ignition module, fuses, fuse relays, replaced alternator plug, still did not fix the problem. I finally took it to an auto electrical shop and $400 later for that visit. It turned out according to them, and so far they are correct, was just a matter of wrong size battery frying out the alternator.
The issue I was having with mine is just about the same. It's an 84 however. Charge light intermittently going on and off. Fired off the parts canon early since in my previous experiences it had been the alternator. Well, got the new to me/rebuilt alternator installed and the problem persisted. Started checking the proper wires like I was instructed on this fine site and found that the wires going into the regulator were loosened somehow. If I'd cram them up into the regulator, the alternator would start charging. Bought a new regulator and the problem went away for a few weeks.
Now my issue is that immediately after start up, the charge/brake light comes on and stays on until the engine warms up. Charge light goes off for a few seconds, comes on for a few seconds, then goes off and stays off for the rest of the day no matter how many times I shut off and restart engine.
The next day I go through the same cycle again like freakin' Groundhog Day.
Have the day off today so I'm gonna look into it further.
Not sure if your regulator setup is the same as mine but I'd check the voltage on the wires going in and coming out to see if you are having the same issue.
Good luck.
Good luck.
