W58 fifth gear into a W56?
I have been pondering if you could find a lower gear for fifth too.
I have to drive my truck a 100 km to my folks place and 330km to the cottage and 360 if I go to my folks place then the cottage (thanks Google maps
) and a great deal of that is on expressways and highways. and i wouldn't mind a slightly lower highway rpm I usually cruse around 90 - 105 km/h (55-65mph) on the highway depends if i have to be anywhere. and if i recall correctly the truck is usually doing 2200 - 2700 rpm (but don't quote me)
From: Downtown Heckronto, Ontario, Soviet Canuckistan
The 5th gear in a W58 is the exact same as the W55's 5th gear. The ratios in a W58 are offset because of a different input shaft, but they are the same ratios otherwise. Swapping in a 5th gear out of a W58 is the same as taking it out of a W55, which is the same as leaving things as they are in your W56.
justdifferentials
Just Differentials
Jul 22, 2015 08:26 PM
shadowbirdie
Jul 21, 2015 10:38 PM
WTB[PacNorWest]: w56 c manual trans with t-case and drivelin
89hilux1
Jul 19, 2015 01:32 AM
