W58 fifth gear into a W56?
Old May 6, 2010 | 01:22 PM
yogmuney's Avatar
Does anyone know if you can put a W58 5th gear set into a W56? Would make for a nice RPM drop for freeway cruising.
Thanks.
G
Old May 6, 2010 | 01:25 PM
waskillywabbit's Avatar
Seriously? Freeway cruising?
Old May 6, 2010 | 01:29 PM
yogmuney's Avatar
it's my only damn car. :-)
Old May 6, 2010 | 01:35 PM
yogmuney's Avatar
besides, when do you use 5th gear when you are wheeling?
Old May 10, 2010 | 04:13 PM
ilostmypants's Avatar
I have been pondering if you could find a lower gear for fifth too.
I have to drive my truck a 100 km to my folks place and 330km to the cottage and 360 if I go to my folks place then the cottage (thanks Google maps) and a great deal of that is on expressways and highways. and i wouldn't mind a slightly lower highway rpm I usually cruse around 90 - 105 km/h (55-65mph) on the highway depends if i have to be anywhere. and if i recall correctly the truck is usually doing 2200 - 2700 rpm (but don't quote me)
Old May 10, 2010 | 06:10 PM
peow130's Avatar
Shoooot. I do 70MPH on the freeway with 4.30's in the rear and in 5th gear.
I don't think you need a lower 5th, lol.
Old May 10, 2010 | 06:15 PM
vital22re's Avatar
totally a bro
hey i wouldnt mind free way rpms to be at 2600 for 70 otherwise i'm at 3000 not very economical.
Old May 11, 2010 | 04:46 AM
Magnusian's Avatar
From: Downtown Heckronto, Ontario, Soviet Canuckistan
The 5th gear in a W58 is the exact same as the W55's 5th gear. The ratios in a W58 are offset because of a different input shaft, but they are the same ratios otherwise. Swapping in a 5th gear out of a W58 is the same as taking it out of a W55, which is the same as leaving things as they are in your W56.
Old May 11, 2010 | 09:47 AM
Keith B.'s Avatar
Economical and 70mph don't really go together. If you really want to save gas, make the trip at 50 or 55mph, mostly in 5th gear. Yeah, I know, I don't either.
JAmdor3
Aug 11, 2015 10:53 AM
norcal98
Aug 10, 2015 06:20 AM
justdifferentials
Just Differentials
Jul 22, 2015 08:26 PM
shadowbirdie
Jul 21, 2015 10:38 PM
89hilux1
Jul 19, 2015 01:32 AM
