99 toyota 4runner runs rich
Old Apr 27, 2010 | 09:06 PM
kauai_toy91's Avatar
help if anyone had this happen to them. My runner starts up great on its first initial startup then through out the day as I turn off and turn on my vehicle it starts to take longer to start up and when im starting the vehicle I can smell raw fuel from the tail pipe. The only way it would start is to press the fuel pedal to the floor and keep it there while I crank on it. When it starts the motor sounds like it's missing, also thick grey smoke comes out the tailpipe and the idle would stay rough for a minute or so.
things i did:
-swap ECM
-r/r idle air
-r/r map
-cleaned throttle body
-poured some expensive inject. cleaner
Old Apr 27, 2010 | 09:13 PM
Crywolf's Avatar
You should probably at least clean if not replace your plugs. Even if they're not the culprit they're surely pretty carbon'd up now.
Old Apr 27, 2010 | 10:26 PM
icebear's Avatar
I hope more people respond, I've got a similar problem. The only diff is that I cleaned and then replace the cold start injector and it still does it.
Old Apr 27, 2010 | 11:28 PM
yotaman85's Avatar
its your o2 sensor.....
Old Apr 28, 2010 | 05:16 AM
496 BB's Avatar
Not sure how you check it but check your fuel pressure regulator. Or at least check the vacuum lines going into it.
Old Apr 28, 2010 | 01:19 PM
Ken's Avatar
Ken
Might want to change your spark plug wires as well. My exhaust was pretty sooty but cleared up after changing the wires.
Old Apr 28, 2010 | 03:06 PM
icebear's Avatar
Ok, I've done the cap, plugs and wires, but not the O2. Just to be sure, it's located just before the muffler. Right? Or is there a second one I don't know about?
Thx Yotaman
As far as the fuel regulator, does anyone know how to check it? Or, is it a cheap part you just replace?
Old Apr 28, 2010 | 08:40 PM
the funny thing is that it does not pull any codes
arlindsay1992
Jan 23, 2024 01:34 PM
vasinvictor
Jan 20, 2016 12:39 PM
JaredL
Jun 16, 2015 04:47 PM
