high idle and tap tap tap.....boom?
Mine was doing that when I first got it...then I hydro-locked it. I believe it's your valves making this noise. Seems like it in mine, when i locked it she really started ticking. Now it's not rapping like a rod bearing, I have a parts truck that does that. This seems more like a valve sticking, I have not had a chance to tear into her yet.
almost all my valves were tighter than spec... so im hoping that's what the noise was from! just waiting on the valve adjustment tool to get here(ups is slow BTW). nor cal if you let the ticking go u may have a chance at burning a valve, that's the reason i had to get a head job...sucks and is way expensive!! i couldnt imagine what a shop would charge in labor to pull your heads!
A $10 set of feeler gauges, a 12mm wrench, and a flathead screwdriver are all that are needed to adjust valves. You can do it yourself in about 30 minutes. It's quite easy.
so i finally got the valve tool in on monday night so ive been working on it today. i was able to change around shims and get all but 2 valves within spec! on the passenger side all the exhaust valves were too tight and the intakes were too loose and only 2 were outta spec on teh driver side. crazzzzy! i couldnt even get a .002in feeler in most of the tight ones! so running to the stealer again tomorrow....i pray they have these in stock!
for first timmers ummmm maybe more like 3 hrs(i would include myself in that category lol)... lots of measuring writing numbers and micrometering!!!! and i believe it could be done without the valve tool but its just soo much easier with it!
If there's no exhaust leaks, and you're not tossing any engine codes, valves would be the thing to check.
These are shimmed bucket valves, have fun adjusting em
http://myweb.dal.ca/is353832/93fsm/index.html
u want me to make a video or something lol?
