22re stock exhaust
22re stock exhaust
Hello~When removing the stock manifold from my 22re I just realized that I'll have to replace the little gasket on the 'secondary air injection manifold.' Can I cut one out of a sheet of gasket material I used for the fuel pump bracket or does it have to be rated for high temps? The old manifold developed the infamous crack at the 'Y' so I got a new stock manifold. Thanks in advance for any replies.
I think they are Designed for high heat conditions. . You need the manifold gasket and also the two exhaust flange gasket.Also the two with you talking about .. Can't think of the name ..but they should come with the exhaust gasket set .
Jun 1, 2021 01:51 PM
