Fixed the Even Gear Shifting Problem
After installing my 3" 4Crawler BL I had problems keeping my truck in 2nd and 4th gear (would pop out of gear as soon as I let off the gas). Roger has some really good information on his site to fix this and I am hoping that me making this thread will make fixing this caveat even faster.
Like my sig says I am running a 1994 Pickup 2wd 22re with a short bed. To fix the shifting problem I pulled up the carpet in the cab and accessed the Rounded square retainer that holds the shift boot in place. I unscrewed the retainer and pulled the 2, yes that is 2, shift boots apart. The inner boot I inverted and pushed down below the cab and then put everything back together.
After finishing this I realized it might of been easier to just stick a coat hanger from below the truck up inside the Shift Boot to snag the inner boot and bring it down. I did not know there were 2 boots though
I hope this helps someone else who may be in the same situation. May just save some time!
.I hope this helps someone else who may be in the same situation. May just save some time!
Jnkml
Jul 6, 2015 01:20 PM
