Adding second 80 amp fuse.
Old Mar 20, 2010 | 10:20 AM
LITLRED's Avatar
I need to add power to a accessory fuse block and noticed that it looked pretty simple to add a second fuse next to the stock 80 amp fuse.
Looks like all I need is to upgrade the existing feed from the battery, pick up a new fuse and another brass screw. Seems too easy. Has anyone done this before?
Old Mar 20, 2010 | 10:57 AM
mt_goat's Avatar
Interesting idea. I have added a 2nd cable to upgrade the line to the alternator (part of big 3 upgrade), but I didn't notice the slot for another fuse. I purchased a 100 amp inline fuse for my extra fuse block.
Old Mar 20, 2010 | 04:37 PM
myyota's Avatar
There is a space for another fuse next to the main 80 amp fuse, but if you add another fuse there it would be a real good idea to upgrade the power wire from the fuse box to the battery with a heavier wire. I would go with at least 6 gauge battery cable at a minimum, the stock wire is 8 gauge.
Old Mar 20, 2010 | 04:43 PM
LITLRED's Avatar
Here's pics of the added fuse...
[IMG][/IMG]
Old Mar 20, 2010 | 04:50 PM
1990yota-pickup's Avatar
looks stock, expect you dont have a matching screw...
you might through the guys off at the dealership..
Old Mar 20, 2010 | 04:52 PM
camo31_10.50's Avatar
what's the need for the added 80amp fuse? lol
Old Mar 20, 2010 | 04:53 PM
on a side note..i wish i had a nice unbroken fuze box like that
Old Mar 21, 2010 | 05:59 AM
LITLRED's Avatar
Added a power antenna and want to add some lights and a compressor etc.
Old Mar 21, 2010 | 06:04 AM
LITLRED's Avatar
I was too lazy to find a stock screw...just used what I had.
Old Mar 21, 2010 | 06:21 AM
LITLRED's Avatar
yea...I thought so too so I added some 12 gauge wire I had in my electrical box.
It looked simpler to add a wire than to replace the factory 8 gauge. It is crimped to a brass plate that connects both sides of the fuse block. Toyota chose not to run the headlight circuit through the 80 amp fuse, which makes sense to me. I wouldn't want to lose both headlights if 1 fuse blew!
Old Mar 21, 2010 | 07:19 AM
you, should put a light bar on your rigg,
Old Mar 21, 2010 | 07:46 AM
mt_goat's Avatar
Just a note, my battery to fuse box line had a fuseable link. If you upgrade that I'd either keep that fuseable link or add another one.
Old Mar 21, 2010 | 08:19 AM
LITLRED's Avatar
My battery to fuse box line has been fubarred by the PO. Thanks for the advice.
Old Mar 21, 2010 | 08:27 AM
abecedarian's Avatar
I saw the pic and I'd be worried about the size of the wire leaving the 80a fuse. What gauge is that?
Old Mar 21, 2010 | 09:11 AM
looks like 10ga on the right and 8ga on the left ? hard to tell without holdin THE WIRE in my hand lol
Old Mar 21, 2010 | 09:15 AM
hard to tell without holdin it in my hand lol
remind me to not go out drinking with you.
Old Mar 21, 2010 | 09:19 AM
oh wow.....somethings just sound better when they are in my mind rather than on a laptop screen....LOL
Old Mar 21, 2010 | 09:20 AM
i don't drink anyway..i'm underage
Old Mar 21, 2010 | 09:27 AM
So, you're saying you can't "hold" your own?
Old Mar 21, 2010 | 09:29 AM
Anyhow, I would be concerned that the wire connected to that 80 amp fuse can carry 80 amps. That is the point of having a fuse: the fuse blows before the wire burns.
